Knocking at back left af6et changing discs and pads
I have changed the discs and pads on both side although I could get one pad off so only has one new pad that side but everything done properly I think but bad knocking sound when driving that stops when breaks are on???
Why couldn't you get the other pad out?
Forgot threadlock on calipers, and only 1 new pad went in passenger side as couldn't get piston to retract
If the piston won't retract then it won't move out either.  The caliper will be loose and shifting about on the slide pins to create the knock.  It needs a new caliper fitting.
