Kuga mk3 pcm replacement
A bit of a long shot but are there any recommendations for someone who can do a replacement pcm programming on a mk3 kuga please. I have a unit from an identical spec but I believe it still needs correctly coding
thanks.
In theory you could most possibly do it yourself using FORScan and a vLinker FS cable.
You could download the "AsBuilt" files for your car from Ford and load them to the replacement PCM. I'm not sure about the keys and the immobiliser, that might be a problem because it's a 2016 model.
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
Thanks for that but I’ve already got these. I’m having an issue putting the as built data on though as the as built data from motorcraft doesn’t seem to match up with what I’m seeing through forscan. The as built file has 9 lines of data for the pcm where as I have 26 lines in forscan.
