Kuga FHEV 2.5 - 12v Battery Charging
I have a 23 plate Kuga FHEV 2.5. I would like to connect a CTEK smart charger to ensure 12v battery does not discharge whilst vehicle left unused for a month or so.
Can I connect it to the jump start connection and an earth point under the bonnet OR do I need to connect it direct to the battery under the boot floor?
  • 4 weeks later...
Yes I've the same issue anyone know the ans?
Connect the positive of the battery charger to the "jump Start" terminal, and connect the negative lead of the charger to any good solid earth point, or a metal bolt on the engine.
No need to connect the charger directly to the battery.
There is an earth point near the jump terminal.
  • 4 weeks later...
Anyone know if the ctek lithium charger will rejuvenate my battery with no harm?
The 12v battery isn't lithium is it?  Should just need a normal smart charger for lead acid/AGM batteries.
