Rear door issues
I have posted before about my door open light coming on. I now think that it can possible be the door lock mechanism and it's leaving my side lights on as it's saying the door is open. Is there anyway I can turn the sidelights off . I have also done a check with forscan and it says door control module c and d not found also there is no power when the door open light is on to put down the window
Why don't you just fix the door latch switch ? Or just get a replacement latch assembly from a scrapyard or eBay ?
I have contacted the scrapyards online as my nearest scrapyard doesn't have any cmax instock. I have also done a scan using forscan I will put the picture up of the scan in another comment as it has door module and switch relay.
That is an awful lot of DTC errors.
Have you tried to clear them with FORScan ? I can't believe that they can all be recent/active faults.
Looking at the PDM it would seem possible that the wiring between the front passenger door and the car body 'A' post is damaged.
A need to try and clear them as a think some are old codes. The battery keeps going flat after a couple of days if it doesn't get a long run. A recently just got a new steering rack fitted as it had a power steering issue.
  • 4 weeks later...
I have had the door locking on and off I now have a code b11e9 showing on my car for the rear door could this still be a wiring issue. I have purchased a new lock but I think it's a waste of time as I don't think it's the mechansim
