Battery swap
If I swap batteries for a new one, will I loose any settings ?
Cheers
You may need to reset the 'one touch' window opening/closing but that take two minutes. There isn't any radio codes etc. on your model.
You will need to reset the BMS once the new battery is fitted. Remember to fully charge the new battery for at least 12 hours before fitting.
Hi, thanks for reply. I've had it on my ctek charger for about 3 hours till it's said it's charged......
Not long enough.
1 hour ago, unofix said:
Not long enough.
do I just leave in on charge with the ctex and leave it with the green LED for 12 hrs ?
Yes, it can not get over charged. 👍
and BMS reset - 5 main beam flashes then three brake pushes ? ?
Not sure on that. I thought it was pat your head 3 times while rubbing your tummy 5 times 🤣
See posts below, it will be either method 1 or 2. Just have a look at the style of your light switch/fog light and it will be apparent which method is for your car.
On 3/29/2023 at 8:13 PM, unofix said:
How to reset the BMS method 1        Search Tag: BMS1
On 3/29/2023 at 8:14 PM, unofix said:
How to reset the BMS method 2        Search Tag: BMS2
I think the later cars are the Main Beam method because some American cars don't have Fog Lights so Ford have changed.
