DTCs after spanner (powertrain) warning light
I went out yesterday and drove about 40 miles in total. Made two stops before returning home, so the car was driven 3 times. On my first and second trips I had the powertrain/spanner light come on and message to see manual. Almost instantly the engine power is cut off and i had no acceleration at all. Interestingly both time seem to have been when going uphill like Habbers on a separate topic experienced with his. To clarify when setting off on the second trip there was no warning light until later on. I then made my third trip/way back home and had no warning light.
I drove the car today to do shopping locally and again no warning light but the terrain was less demanding/not that inclined and I drove only about 10 miles.
I used forscan to check for DTCs and I have found the folllwing:
===PCM DTC P06DD:00-68===
Code: P06DD - Engine Oil Pressure Control Circuit Performance/Stuck Off
Status (-68):
 - Previously Set DTC - Not Present at Time of Request
 - Malfunction Indicator Lamp is Off for this DTC
 - Test not complete
===SECM DTC U3003:1C-48===
Code: U3003 - Battery Voltage
Additional Fault Symptom (:1C):
 - Circuit Voltage Out Of Range
Status (-48):
 - Test not complete
===SECM DTC U3003:68-48===
Additional Fault Symptom (:68):
 - Event Information
Status (-48):
 - Test not complete
===SASM DTC U3003:1C-08===
Status (-08):
===ABS DTC U2002:96-60===
Code: U2002 - Switch
Additional Fault Symptom (:96):
 - Component Internal Failure
Status (-60):
 - Test not complete
===DDM DTC B1166:15-48===
Code: B1166 - Right Front Puddle Lamp Output
Additional Fault Symptom (:15):
 - Circuit Short To Battery Or Open
Status (-48):
 - Test not complete
===RCM DTC U0557:82-28===
Code: U0557 - Invalid Data Received From Front Controls Interface Module 'A'
Additional Fault Symptom (:82):
 - Alive/Sequence Counter Incorrect/Not Updated
Status (-28):
I have noticed that the powertrain issue probably is the same as Habbers had here:
Am I looking at having a sensor replaced also?
I have attached the complete DTC log, as I would appreciate it if someone who is more experienced than me can tell me what I am looking at.
Is it just worth taking it to a ford service branch?
dtc log.txt
