Date on diasplay of 2014 Kuga
Each time the battery is disconnected on a Kuga with a Sony audio the 'Date' on the display reverts to the build date; in my case 2014. The user manual gives no instructions on how to reset it, how ridiculous. You can alter the displayed 'Time' with the audio unit turned off but not the displayed 'Date'. The audio must be turned on and you need to select 'Menu' where the chage date function will be displayed. Ford's support function says ' you should take the car to a Ford dealer'. Thank you Ford.
11 minutes ago, Keith Britton said:
Each time the battery is disconnected on a Kuga with a Sony audio the 'Date' on the display reverts to the build date;...
Why are you disconnecting the battery? Apart from replacing it, it's usually left connected?
