Kuga Mk1 Front wheel bearing kit
Is the front wheel bearing on a Kuga Mk1 a press fit or does it just easily push out once the 'C' clip is is removed ?
Also is it worth paying an extra £125.31 for a Ford supplied part ?
From Ford: £163.20   https://www.ebay.co.uk/p/1443625920
From 'JP Group' £37.89    https://www.ebay.co.uk/itm/403333750201
Bearing Kit - finis 1836381
If it's like a lot of other Fords then you will need a Hydraulic Press and  different sized Remover/Installer Drifts(for want of a better word), Shells etc so that the new Bearing does not get damaged when it is installed.
I hate paying anyone to work on my cars but Front Wheel Bearing replacement is a thing that I would not attempt myself.
As for the make, I think Bearings generally are all much the same provided they are from one of the big suppliers.
Press to get bearing out after pressing the hub out first.
That's a pity 🙁
So a big hammer sounds like it's not up to the job 🤣
6 minutes ago, unofix said:
That's a pity 🙁
I tried that with a drum bearing once.  Ended up smashing a lump out of the drum.  The bearing didn't move. :laugh:
Took the other one to my local garage to have pressed out properly. :wink:
