Mk 7 Anti Roll Bar bushes.
I can't believe this topic hasn't been aired many times before but a  many-keyword search has failed to locate it.
Are the Fiesta Mk 7.5 ARB bushes easy to locate for lubrication (WD40 or silicone spray) without a hoist?  The perrenial squeak has returned.
Solved by tux850
  • Solution
They are readily accessible (easiest with the wheel off, but full-lock steering might be sufficient), however if they're squeaking that suggests they're slipping which in turn means they are likely worn and so could ideally do with replacing at some point soon.
