Fiesta ST 7.5 Dome/Interior Roof Lights Wiring
Does anyone happen to have a wiring diagram or some wisdom about the interior reading/dome lights?
I have just replaced the antenna base and so needed to get behind the dome light unit (base replaced successfully!) - but when unclipping the light unit a cable became unplugged, and I can’t see any obvious place where it should go? Any ideas much appreciated!
Solved! Had a better look at it after work and could see a copper “pin” sticking out that looked like a good candidate to try. Photos below.
Will leave the post up in case anyone else manages to do the same as I could not find any pictures of this part anywhere! Seems the wire was for the red ambient lights.
