Fiesta 2015 Intermittent Starting
I’m having an issue with my Ford Fiesta 2015 Ecoboost. The car has an intermittent starting problem — sometimes it starts perfectly fine, other times I turn the key and get absolutely nothing. No crank, no click, just silence and it’s happening more frequently.
To try and solve it, I’ve already replaced both the clutch switch and the ignition switch, but the problem is still happening. The battery is fine.
Sometimes when the car won’t start, it will work when I move the gear stick into gear as i turn the key.
Has anyone else experienced something similar or have any idea what else I should be checking?
Thanks in advance!
Little progress is going to be made with out the use of FORScan.
