mk5 cranking but not starting ?
hi folks, we have a Mk 5 sometimes it cranks but doesn't start, wait a few mins and it starts other times it starts no problem
changed the coil pack, still the same, I can hear the petrol pump running before I try to start it
is there a relay that feeds the coil pack ? (thinking could be fauty relay ?)
anything else  I should look at ?
hi m8, could try obd, see any faults, so many sensors these days, guess you tried plugs and air filters, maf sensors may need a clean,but only use proper maf cleaner if you do, good luck
no faults showed on OBD test, Got a DS150e tester and software so bit more than basic tests
it can give Live Data but not sure what Live test I should do when car is running
as its an inttermittant faut its a pain to find, but If it was a sensor fault it would have a log record
could it be the crankshaft sensor ?  its an intermittant fault, no fault codes
anything to check to see if crankshaft sensor
A live data feed of its output.
Mine does this sometime and I find it's immobiliser switch off lock open then starts I've also known throttle bodies be bit tempramental
