Wet belt
Hello  i am looking buying a 2nd had Fiesta. i have been googling the prices of getting a wet belt changed .
why is it a lot more expencive to get it done for a 1.0 echo than the 1.6 st echo?
i am currently deciding between a st or a st line
The 1.6 EcoBoost does not have a wetbelt.  That uses a conventional dry belt.  That's why it is a much cheaper job.
Presumably you're talking about the Mk 7.5 (2012-2017)?
In which case the answer is the 1.0 is the "wet" belt which is a complicated and very expensive job to replace, while the 1.6 ST is a conventional "dry" belt and much less labour intensive, hence cheaper.
thanks i was under the impresion they were both wet bets. that make more sense now
