C-Max No Rear Camera or Parking Sensors
Hi all, new here. I have a problem with the wifes 2015 C-Max.
it is a titanium with F&R parking sensors and Rear camera .
on start up, she is getting a parking aid malfunction fault. Sensors do not work and nor does the reverse camera.
i ran forscan and the only fault im getting is a U0159 code and no PSCM communication PAM A
here is readout. Can anyone shed light?
Code: U0159 - Lost Communication With Parking Assist Control M
Status (-0A):
  • DTC Present at Time of Request
  • Malfunction Indicator Lamp is Off for this DTC
Module: Power Steering Control Module
Freeze Frame #1:
  • EVENT_TIME: 333751905 s (Sat Jun 14 19:08:53 2025) - Event tim
  • TOTAL_DISTANCE: 64647 km - Total Distance
  • MODULE_VOLTAGE: 11.8 V - Control Module Voltage
  • OUTDOOR_TEMPERATURE: 17 °C - Outside temperature
PWR_MODE_KEY: Ignition On - Power Mode Key State
  • PWR_MODE_QF: Power Mode OK - Power Mode Quality Factor
  • SS_TRQ2: -0.5 Nm - Steering Shaft Torque 2
  • ECU_POWER_SUPPLY: 12.0 V - ECU Power Supply Voltage
  • ECU
    _INTERNAL_TEMPERATURE: 20 °C - ECU Internal Temperature
  • VS3: 0.0 km/h - Vehicle Speed
  • DLA_SED_FDOB_PID: 129 - DL_SED_FDOB_PID
  • DLA_NUM_FDOC_PID: -0.02 A - DL_NUM_FDOC_PID
  • DLA_NUM_FDOD_PID: 0.00 A - DL_NUM_FDOD_FID
  • DLA_NUM_FDOE_PID_1: 0.0 Nm - DL_NUM_FDOE_PID_1
  • DLA_NUM_FDOF_PID_1: 0 1/min - DL_NUM_FDOF_PID_1
First, are you using FORScan to read the DTC's or some generic code reader ?
Second was the car originally built with the equipment or has some one tried to retro fit it ?
I used Forscan and i believe it is all OEM equipment.
i have no other fault codes on the vehicle, apart from the one above
i have checked fuses and PAM module. All are ok
If you let me know your Reg, or VIN, I can have a check of the Ford build sheet to see if this was factory fitted.
Are you using the vLinker FS cable with FORScan ?
Reg is
EA64 EWS
im using an elm327 for forscan
Ah Ha !!! 😀
That will most likely be why you are having communication problems. Vehicles built 2013 onwards need to be connected using the 'vLinker FS' cable which auto switches between the MS and HS canbus and has a higher data transfer speed. The current versions of FORScan no longer properly supports the old Elm327 cable.
Can confirm your car was factory fitted with front and rear parking sensors and camera
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
OR
For diagnostic use only:
Factory Build Sheet:
REG: EA64 EWS
VIN:  WF0JXXGCBJER08698
Build Date : 21.10.2014
Vehicle Line : C-MAX 2010-2015
Engine : 2.0L DURATORQ CR TC - DW10C
Transmission : 6 SPEED POWERSHIFT 6DCT450 - MPS6
Emission : STAGE V EMISSIONS
Air Conditioning : DUAL ZONE AUTO TEMP CONTROL A/C
Body Style : 5 DOOR UAV
Drive : RHD FWD
Axle Ratio : 4.067/2.905
Version : SERIES 55
Exterior Paint : FROZEN WHITE
Interior Fabric : PUR/LUX /SYRACUS
Territory : (+)"GB"
start warranty: 23.10.2014
Owner’s Manual (Vehicles Built From: 3/3/2014) (HTML)
history
whl spd sensor w/dir regn
3.58/1.95/1.19/0.84/0.94/0.79
reverse parking aid
front parking aid
rear floor mats-velour
front floor mats-velour
less daytime running lamps
halogen headlamps
automated parking system
less side parking aid
standard duty suspension
electrochromic inside mirror
window auto close
less driver exterior mirror
front fog lamps
pwr frt w\'dows one touch up/dn
pwr rear 1 shot up/down window
less passenger exterior mirror
dual pwr/heat/fold/pud lamp mr
tinted glass-complete
less sun blinds
ext mirror finish-body color
deluxe headliner
grl-upper blk msh/chrome surnd
sunvisor,single-pass illum
sunvisor,single-drv illum
less windshield heat shielding
door handles-inside aluminum
saarlouis plant build
interior lighting-ambient led
less security lock group
less special equipment package
frt individuala and rr map lts
less convenience group
floorwell lights
front and rear lamp led
less mkt flex prep pack
less rr overhead reading lamps
instrument panel stowage bin
less rear intr assist hndl
glove box lights
less frt roof intr assist hndl
less sales badge
load space plowage box
load compartment light
less cargo net kit
less roof line conversion
ford corporate badge
less svo application/label
less aux interior lights
electrical outlet #1
less rear splash guards
electric windshield defroster
electric rear window defroster
less power point plug
frt door scuff plates-titanium
cargo area cover
load compart. tie down loops
ls drv st back mtd map pocket
automatic windshield wiper
intermittent rr wnd wash/wipe
rear view camera-fixed
4.067/2.905 final drive ratio
less cargo compartment net
ls pass st back mtd map pocket
heated washer jets-w\'shield
load floor carpet
taillamps-level 1
less cargo stowage device
less first aid retain straps
less headlamp cleaning
less radio pre-equipment pack
high mounted stop lamp
marketing level 1
less warning device ret straps
frozen white
no description available
accessory media hub 1xusb
less radio information decoder
less auxiliary compact disc pl
great britain
less a/v jack
less blue tooth interface conn
less cool box
less run flat system
less interior pack
less fold flat front pass seat
less style pack
front headlamp leveling
automatic headlamp control off
less dress up rso
ice-mid audio branded +dab
less svp
less radio antenna
ice feature pack 14
less console ashtray
exterior paint - solid
l/frt splash guards/mud flaps
less program controls
less temp controlled glove box
less front seat center armrest
branded icp w/ nav
less under seat stowage drawer
padded dash
electric power steering 1
less drivers seat armrests
less seat-special covers
less tonneau cover
less pass seat armrests
less roof opening panels
driver seat recliner-rotary
less seat special covers-rear
front 2-way headrestraints
less seat special covers front
less passenger seat recliner
less interactive vehicle dynam
overhead console-high series
less tray/table - front
console-floor-full w/ armrest
less rear floor consolette
normal temp zones
9 radio speakers
less inbound modification cent
less radio subwoofer
less rear seat fold down
rear seat center armrest
rear headrestraint-2 way
less tailgate badges
headrestraint-rear center
lumbar seat supt-driver seat
lumbar seat supt-pass seat
hill launch assist
less telephone prep pack
conventional instrumnt level 3
less mobile office pack
instrum cluster-rheostat
less family entertainment syst
less water wading equipment
less radio noise supression
rear passenger door
standard duty battery
less cellphone interface systm
strg column-tilt/telescoping
rear duct / b-pillar
less temp control passngr seat
less temp control driver seat
less air purification sensors
sync (media gateway module)
less voice activated modules
filter cowl air intake
st belt mndr-dr&pas/eu tel&snd
less luggage compartment mat
less u/body corrosion protect
less brake system-regenerative
less interior partition
less driver roof storage
second row-3 individual seats
less third row seating
mph/kph speedometer
recirculation heater
manual 4-way drv seat adjuster
non locking capless fuel fill
diesel fuel capability
manual 4-way pass seat adjust
less gaseous fuel prep pack
voltage regulator-12v socket
trip computer
strg wheel radio controls
ls column stalk radio controls
foot pedal design - standard
fixed foot pdls
less handbrake grip
park brk-mechanical hand oper
less frt bumper sensor device
liftgate - manual
less air conditioning
steering whl-4 spk leather
speed control & asld
frnt bumper-painted body color
less front bumper extension
seat-individual-l/b drv/pass
rear bumper-painted body color
rear brake - disc
less accessory-packages
less rear bumper extension
less collision mitigation sys
kit-enhanced tire repair svc
less city safety
single exhaust system
electronic emerg brake assist
less restraint devices
less underfloor stowage
less front grille
less knee protection
grille-lower surr hgh gls chrm
less roof rack
less exterior bodyside mldgs
less exterior rocker panel mld
bright ext.door frame molding
dual note electric horn
brakes-hla/esp/tc/abs
air curtain restraint-lh
less rr seat belt pre-tensionr
less rr seat side airbag restr
less spare wheel
less radiator shutters
less aux roof rack crossbars
less beltminder
tire pressure sensors-433 mhz
active seat belts-front
less block heater receptacle
rr seat belts-3 point/inerta
air bag restraint-pass
air bag restraint-driver
comp unique for alloy whls
pass seat air bag restr
tire inflation monitor lvl ii
driver seat air bag restraint
7j x 17 style 5 alloy wheel
mfd nav low tft screen
less pass air bag deactivation
less compass display
manual adj frt seat belt mount
isofix hard point attachment
tether anchorage restr-style 1
message center
less navigation center
ext door handle-body color
less frame mntd fuel filter
less navigation disk
lift/decklid hndl ext-body clr
nav data - western europe
leather gear shift knob
key combination pack 1
less emergency system
steel sec door lock shield
supplemental air heater
preprogrammed speed limit
chld prf rr dr lk + elec rel
emergency assistance
remote deck/tailgate release
less door auto relocking
215/50 x 17" w rated bsw tyre
less park heating
less rear spoiler
less second remote ign key
less trailer coupling
less spare tire
less lane departure warng syst
less towing pre-pack
power door dead locks
less driver impairment monitor
less door unlock system
door entry remote cntr unit
standard tire tread-front
keyless start
standard tire tread-rear
less blind spot info system
less lane keeping aid
less speed sign recognition
capless fuel filler w/o lock
less trailer sway control
int environ color-fairland
int feat-color-syracus
less immersion heater
starter equipment (-15c)
std electric starter
less floor mats-3rd row
less remote starter
less homelink
less wheel covers
locking wheel lug nut
auto headlamps-follow me home
market road condition-general
thatcham category 1 alarm
fog lamp bezel-chrome
engine immobilizer\'securilock\'
Ok. Thanks
i will order the correct obd lead before getting it into garage
would a single sensor, shut down the whole system?
seems extreme if so
Yes, one faulty rear sensor can disable the whole of the rear parking sensors, but not the camera.
I wonder if a module has reset and disabled the camera?
i have had to update the sync system recently
thanks
Disconnect the negative lead of the battery for 20 minutes.
Reconnect it and WAIT for 5 minutes before turning the ignition back on. This will reboot all modules.
Water ingress in PAM in boot, that why it's lost COMMs.
PAM will be in rear 1/4 covers/panels
Remove or find PAM and read full Ford part number on it xxxx-xxxxx-xx
Ensure 2nd hand replacement PAM is "exactly " the same part number, not one letter or number can be different
Fit replacement PAM, it will be plug & play
That ELM will read that C=Max OK
So, i have scanned with the vlinker lead and i am still getting the above fault
Any ideas?
Did you delete the car's previous profile from the laptop, and then make FORSacn do a full reload of all modules ?
If you used the existing profile then it won't look for additional modules.
Right ok, i think i might have found the problem.
i went into the back and removed module and camera module, when i found this
someone has been at the wires bedore and i know they were not paired up correctly
does anyone have a wiring schematics or a part number to the loom itself?
thanks
