Ford galaxy Titanium x 2012 ecoboost 1.6
Timing belt done,coolant pump done..but it showing engine overhead temperature sensor activated..replaced the coolant temperature sensor...but symptoms are same..on the dash board temperature showing red and engine malfunction displayed...reading the same fault again. Fault codes are P1299-00,U1035-00,P0016-78,P0118-12. Can shaft position sensor replaced...l can only find one that is next to the pulley...don't know if any other.Two sensors of crank shaft also replaced.Coolant sensor replaced...don't know how to go ahead..coolant is heating up...all new coolant and it is coming clear.There was no problems untill replacing the coolant pump due to a leak..bought a Bosch timing belt kit and pump leaked in 8 months .Taken out everything and replaced with a new GRAPH pump looking better and solid than Bosch...coming with proper gasket and metal impeller...Bosch was paper gasket and plastic impeller. Please share any solution if anyone have any clue please.
Was the cooling system vacuum filled ?
Sounds like you have a massive airlock in the system.
How to take out that? All coolant was out and filled with new one
Hi welcome
Hi welcome
It almost taken 4 litter too. Now my coolant tank is maximum
We have tried everything possible...yes it shows some light in to it about an air lock...but how to release the air?Done everything what we have done an year before.
3 minutes ago, dezwez said:
Hi welcome
Hi welcome
Thank you...this is first time l am in a forum
That didn't answer the question. Was the cooling system vacuum filled ?
If not then you will have to remove the filler cap and leave it off. let the engine idle up to temperature and see if the coolant level starts to drop.
No...not vacuum filled...
He
Heard about vacuum filling...but never done before...this is the first time it happens like this
So l have to remove the cap and leave it off..? After how long do l need to start?
Leave the filler cap off the expansion tank.
Let the engine idle up to temperature so that the thermostat opens.
Check coolant level and top up with Ford coolant as required. Repeat this process until coolant level remains constant.
Fantastic and thank you...that is an absolutely valuable diagnosis...thank you so much ...will try that again tomorrow and update the same if it has come out with a result...but thank you so much for your time...same with my camshaft sensor...replaced few times and it doesn't give any result. It shows the fault again after replacing it. Do you have any solution? It was showing before we timing the belt 8 months before .when we replaced the sensor same time as  belts and pump replaced...but again showing fault
You need to use FORScan so that you can get the Ford specific DTC's and monitor live data.
FORScan:
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
OR
For diagnostic use only:
FORScan:
If my symptoms still exist then surely leave to do something...but my first priority is the coolant issue..but thank you for your time...l will surely update once it is fixed. It only showing camshaft correlation bank 1 sensor...how many cam shaft sensors on this car?
