Dab not always finding stations
Morning/Evening all
Has anyone had the same fault or help with a cure.
Am Fm work fine
Dab works fine..ish
If I store a station..reception is fine
If I change station and return to it it often says no reception but may play after a minute or so or not atall.
I have reset the radio to my area and restored but still the same
Also I have an after market dab that finds far more stations on a window antenna
Is the antenna amp failing or even the antenna
Vehicle is a 2011 cmax
Many thanks
Does your radio only have 'DAB' or does it also receive 'DAB+' ?
It has dab and dab+ so led to believe as I can listen to talks port 1 and 2
Still can't find a result
Would the antenna amplifier be failing or would that effect fm/Am that has no fault atall
  • 3 weeks later...
Does anyone with factory dab have the same fault or am I just clutching at straws
