P0193
Hi all, my 1.4tdci suddenly cutting off when Its been running for a bit (20-30 min) as I slow done and in idle. Also when speeding up it starts to kangaroo and keeps juddering. No light on the dashboard but when it cuts off oil light and battery light comes on. Was just wondering if anyone has any idea what it could be. Also P0193 code has come up and it’s running  worse than before when I had P0087 code but this code is now gone. Just the P0193 and I’ve replaced the fuel filter, fuel rail pressure sensor and fuel rail pressure regulator and still no luck.
  • 5 months later...
Hi
Did you resolve this problem? I have exactly the same problem...
  • 4 weeks later...
Hi mate, yes I did in a way that code went away but It was the loom that connects to the injectors shaved a bit and was pulling more amps than normal. I replaced it and the code went away, but now I have the issue of my car starts as normal on cold but as soon as the engine warms up it starts lagging on power when it’s been driven for about 10 min or so.
