Vacuum leak?
When I push the black pipe leading from the air intake with the white pipe from the side of the rocker cover it sounds as if there is an air leak. I have a fault code of p0101 and p00bd and was wondering if this could be the cause. I will attach a photo underneath, If anyone can confirm if the pipe is chafed or what else could be causing this. Thanks
If you think there is an air leak when you push the pipe and hear a sound, there probably is - is the pipe cracked, just inspect closely and replace as necessary, see if the codes go away then work from there?
I can see it goes to the back of the engine I will try to find the part number and find where it traces to.
