Ford Connect 1.5 p2002
Hello! I have a Ford Transit Connect 1.5 Ecoblue 2019 Engine Z2GA on which I have installed an aftermarket particulate filter from JMJ Automotive. 300km later After that, I have the same error code as before: P2002 Diesel Particulate Filter Efficiency Below. If I delete it, it takes about 200-400 km before it comes back again. The differential pressure sensor reads 2 mbar, and after replacing it with a used OEM pressure sensor and reset dpf pressure adation.  the car reads 13 mbar at idle and around 30 mbar at 2000 rpm. i think this solved the problem but after drive again and 200-400km the light comes on again... Do these particulate filters require a different sensor than original? I'm starting to give up... Here is the link to the filter I bought: https://www.autodoc.se/jmj/20444396?utm_source=email&utm_medium=email&utm_campaign=orderConfirmation&utm_term=link9&deep_link=orderConfirmation&kmtx_hash=eyJtaWQiOiJ1aWQtNjg0MTdhMzMyNzUzOTMuMTQyNzI2NjQiLCJob3N0IjoiYXV0b2RvYy5zZSIsInR5cGUiOiJvcmRlckNvbmZpcm1hdGlvbiJ9
@Admin Duplicate thread
