C max warning lights on dash
Hi all.
help please. Grande c max 2019 2ltr diesel.
after travelling 10 miles all warning lights come on for. Hill start, Traction control, abs, city stop,
and reverse sensors don’t work. When just starting off in the morning there are no lights on, except for the initial check when ign switched on, and everything works as it should, but as soon as everything has warmed up the problems start.
can anyone recommend an expert that could sort for me please, or a fix I could do myself.
thank you
Problem is either:
Vehicle battery has a low State Of Charge.
OR
You have a failing ABS wheel speed sensor.
If you use FORScan it will tell what the problem is. If it is one of the ABS sensors it will tell you which wheel.
On 9/10/2025 at 12:37 PM, unofix said:
Problem is either:
OR
forscan is good software
On 9/10/2025 at 12:32 PM, peter Davis said:
Hi all.
thank you
hi, two months ago i was driving on a bridge and as I went over a hole,i've got the same problem  , i used obd2 with forscan , i cancelled all the errors "i know is not a good solution" then i uploaded the battery,i didn't have any light  on the dashboard until now  maybe it's a coincidence but it worked
