Transit Connect Fuel Return Line Problem
Hi
I have ford transit connect 1.6tdci 2014.
I have an issue where engine is running rough when everything is connected as is should be.
I did injector leak down test and while doing it engine was running perfect.  I have eliminated injectors, all 4 running at the same numbers.
When the injector return fuel line is disconnected engine is perfect, when connected back in again engine is running rough/ knocking sound from around 1200 to 2000 revs. All this goes away when the return fuel line is disconnected.
I got the second hand return fuel line but that hasn't solved the problem.
Is there something else I should be looking at? Where could be the problem?
I really appreciate all the help.
I was going to suggest a kink or blockage in the return line.  But if two are the same then it can't be that.
Possibly a blockage on the connector where the end of the return line is?  Are there any valves after the return line that could be stuck closed?
Thank you for your suggestion.  I had a good look at the lines and there seems to be a valve, right passed the double connector. Maybe I am just very unlucky to have 2 sets of lines that are blocked? I have used sirange to force some diesel into the line and a lot of black diesel came out. I have left it overnight with the injector cleaner to see if that helps.
I will attach the picture of the line from the interent. There seems to be a one way valve just pass the double connector.
I will update on the progress.
  • 6 months later...
Hi
How did you get on??
