2021 Ford transit connect Sport.....Battery?
Afternoon all on this stormy cold afternoon.
I've been away for a bit, my FTC Sport Van was all ok, but the battery is now dead as a dodo. Been ok when left for a month, is it possible the battery can be removed, put in a warmer environment indoors and put on a charger or smart charger for discharged batteries? Or Is it just dead?
If so which replacement battery do i need, there's so many and all different numbers n letters? Looked everywhere and a bit confusing is an understatement having goggled this many many times. The battery in there is a VARTA AGM 80aH 800A, the original number on the label says DV6T-10655-BC. Is it like for like or do owners pop a better/higher output one in? Most of all, is it a clean swap or will i get engine lights flashing, and then need to go to Fords and have it programmed, internet is full of so much do this, must do that.
Many thanks 👍
