Tyre wear help
We've owned our 2020 tourneo custom for 2 years now and almost exactly 1 year ago we put a full set of Goodyear vector cargos on, the front tyres have last approximately 18-20000 is this normal as it seems fairly low to me, one thing I've noticed is the outside edges seem to round off very quickly, at the time of having this set fitted we had the tracking checked and all was ok,
Looking to potentially try the agilis crossclimates, has anyone any recommendations or experience from what I'm suggesting
  • 2 months later...
When l begrudgingly bought a pair of brand new tyres for the mk6 l used to have ( l had no choice as it was running the factory 15" steel rims ) l remember the tyre place saying that the tyres would be good for about 20k giving me time to find a 16" set.. l didn't have it that long 😂 if the outside edge was worn away it could only 1 of 2 or both together..
1 ) improper inflation.
2) the alignment was set so the wheels was slightly toed in and they need toeing out slightly.
You can diy alignment at home without all the expensive stuff. If you have a long very straight piece of wood or metal beam or 1 section of roof ladders that can span the length of the vehicle place it against the middle of the wheel as close as possible back to front. All 4 edges should touch if not then you have the answer to which way the wheel needs doing.
