Spark plug gap size
Hello I have some new Irridium NGK spark plugs but not sure what the gap setting is if you can help?
MK8 ST Line X 2019
The spark plug is a NGK SILZNAR8C7H
It's not recommended to gap iridium plugs as they can be damaged easily.
They should be supplied with the correct gap already. I believe it's 0.7mm for 1.0 EcoBoost.
Ive measured the ones i have are 0.6mm, how much will this affect the performance?
Oh that's interesting. I can't say by how much but it will affect top end performance and potentially emissions as well.
It's your choice whether to try and gap them carefully or whether to return them for a different set.
If you have a plug gapping tool with a notch to bend the outer electrode, there is no danger of damaging the plug.
