Water leak
I seem to have a water leak in my boot not from vents behind the bumper it's coming from in-between the inner arch panel joint and damper panel joint it sounds like there is a pocket of water behind the panel water comes out when i push on the middle of the arch panel.
Any ideas on how to get to and solve the problem as I can't find any drain holes or were its coming from.
Any help would be much appreciated thank you.
Solved by dezwez
  • Solution
Hi welcome
Hi Craig, welcome to the forum 😁
