Slight Squeek
I have an ever so slight squeak coming from my engine bay. I am guessing its coming from the belt system, is it possible to grease/oil the system up?
does it squeak all the time? or is it just when you go to move off sorta thing?
Its like almost impossible to hear, i just hate noises :lol: basically to hear it, i have both windows down, radio and fans off.
It squeaks all the time, stationery and when moving but seems to disappear once the car has warmed up.
i know the feeling, and when you try to tell someone 'listen' they look at you like your alien :lol:
its possibly a tensioner or bearing then? probably impossible to diagnose without actually being there.
has it just started or has it been happening for a while?
Its just started over the last few days. If its any help i doubt anything has been replaced before i had the car and its done 63000 ish now. I opened the the bonnet and had a listen the other day and would say its def the belt area ..... :lol:
its probably a bearing or tensioner then, keep an eye on it, or an ear as the case me be :lol:
I am going to give the fan belt a spray with some WD40, see if that does the trick.
Dont spray that on the belt :o that will make it slip
if your going to put anything on the belt use talcum powder.
A thought that might be the case, but a so called mechanic said to "lager" it on ..... :lol:
is that a so called mechanic i might know by any chance?
Not this time :lol:
Not this time :lol:
sounds like 'you know who's' kind of advice :lol:
wd40 will damage the belt, and more than likely cause it to slip. I suspect your problem lies with one of the bearings and not the belt.
:lol: If it keeps up al get it looked into :P
