Scorpio Diff Ratios ...
Hi ..... Are there anyone who can tell me wich Scorpio diff's are 7 ½ " and what the various ratios are + wich models have what?
Regards Tom
thanks .. the reason asking is that I broke my diff on my Sierra Cosworth and I've been told that the Scorpio 24V diffs should be a direct fit on the Sierra ... any chance that you know if this is correct .. as I've found a diff with these data onthe ID plate : GG ACA 364 1F18 0221. It seems to be missing the first 2 numbers before th GG but the car should be from 91 ?
Regards Tom
been doing a bit of scanning the books,the granada used a 7.5 diff so as long as your cosworth is two wheel drive it should fit.
  • 4 weeks later...
Cosworth diffs were limited slip diffs, Scorpios had traction control so did not, make sure you get a LSD or your driving experience could be ruined
Your diff will be a 3.6
The 2wd and the early 4x4's had 3.6 LSD diffs the only 3.9 LSD is found on the Sierra 2.0 DOHC 4x4
