Oil In Water
my fiesta 2008 van has had a front end bump and i was in the middle of havin it don when i toke the water rad out and out of the bottom hose oil started comimg out but before the bump it was ok just wanted to know what i can do to rectife this is it head gasket , pipes ,etc etc please help
You say the water showed no sign of having oil in it before the bump, where abouts is the oil filter? does it have a oil cooler around the top of the oil filter? if so and it's at the front of the engine then may the cooler cracked on the impact hence mixing the oil/water.
Is the water/oil mix gungy looking?
Thanks for that you were right the oil cooler on the housing of the oil filter took a knock therefore Mixin it thanks a lot dai
