Fiesta 1.25Zetec Kangarooing
Hi
I have an S reg 1.25 zetec fiesta that has developed a severe jolting when using heavy throttle from maybe above idle to approx 3200rpm, in order to use it it has required quite a light foot. Once you creep above 3200rpm it will pull away strongly after that. I've also found that when I dip the clutch when revs are high it takes a while for them to drop down for change.
Car idles ok, seems to rev ok idle. I tried replacing the coilpack so far and no joy, found a breather disconnected to what looked like a MAP sensor. Stuck that back on, no difference. Other than that I'm stumped.
