Focus Mk1 1999 Diesel Pump Tddi
Hi, new to this forum, i was hoping somone would have some information for me. Basically had a lot of problems with the diesel pump.
It had a missfire and cutting out fault, i read lots of forums and came to the conclusion it was the ecu on the pump or wiring..
So i send the ecu off to one of the ecu testing sites that came up on google, to be told there was nothing wrong with it. So i proceed to
change wires i did not need to replace. I then bought a 2nd hand pump and fitted just the pump to the car and used the original ecu.
However this seamed to be okay for a while. Then it started doing it again.
I then decide to replace the whole lot for 2nd hand. Main ECU, chipped key and pump all matched. However when recieving the pump, I
found that the main pulley was not on the pump and there is no keyway on the shaft. Where the hell is the timing mark? anyway i have it
running but its a little on the retarded side i think as its got a lot slower! I dont mind taking it apart for a 3rd time to time it up correctly,
I used all the correct pins and setting bars just would like to know where to time the pump up, dont really want to just guess and advance it :\
Thanks for any help in advance!
