passenger footwell wet
I have a 55 plate Streetka
Under the rubber mat at the passenger side the footwell is wet. The dampness seems to be coming up from underneath and I have checked around door and dash but everything else seems to be dry.
I tried to dry it out best I could last weekend when I found the problem and put newspaper under the mat and today have found it is soaking again.
Can anyone advise on what could be causing this?
Does it have a sun roof if so check the drain to see if it blocked I have used a nylon wire but go gently so as not to disconnect it lower down within the front wheel arch.
