Fiesta 1.4TDCi
Hi, can anyone help?
Due to a previous problem, I have had to change the engine on the wifes 1.4TDCi Fiesta, Which is an 04, The engine I have put in is out of a 58 plate with 1900 miles on it. I have changed the fuel pump as i believe that carries the PATS code, and also I've used the crank & cam sensors from the old engine, and also the mass airflow sensor, due to the connectors being different. Upon starting it will turn over two or three times then stop, and the engine management light flashes, then stays on. I was informed the engines are the same, but now I/ve been told I may need a later model ECU, can ayone shed any light on this? Cheerspost-4287-1235083443_thumb.jpg
