Granada axle! what year?
:) Hello all.
I'm new on here & hope some one can help please? Long story sorry. :huh:
:unsure: What it is, is I bought a second hand Granada 2.5 diesel rear axle! I wanted it for a trike I was building, It has discs & was a IRS if this helps? I knocked all the diff houseing off so no numbers there!
Anyway the wheel bearings went last week but because I didn't know the year no one could help!!
I got a old one out & the code is Y-32008 XZ.
So I go & buy 4 new bearings & put the outer ring in, but the inner bearing it self is 40mm & the wheel carrier shaft is 41mm!!!
So can any one help?
If you can that would be great!
cheers, Dave.
Hi dave,
take your bearing or part number off it and go to a bearing supplies outlet. should find one near to you in yellow pages. could try googling it see what you get?
steve
Hi dave,
steve
Cheers Steve, I got a bearing no' off the old ones & got new.
When I put them back, the shaft wouldn't go through the bearings!!!
When measured, the inner bearing, old one 41mm & the new bearings are 40mm !!
Anyway I got the shaft turned down to 40mm. So no problems in the future, I hope!
cheers, dave
glad you got them sorted mate...
steve
