Small Water Leak
I have a 06 mondeo it has started to drip water I have seen a hose enderneath the engine it look to me either a drain or another hose has com ofit
has yours got air con if so have you been using it if you have thats were the water comes from and is normal after you switch off
thanks for the info I am not sure if I have had the air conditioning on that day but will put it on to see if this is happening .
Thanks could not find any info in manuals.
I also thought it may be where the wiper vent are under the wind screen they I think have to drain away some where through drain pipes
