Water Leak
Hello,i have a 04 st170,79000 mls,it has a water leak from the thermostat housing,its from some sort of bleed nipple and only happens when car started from cold,any ideas?
is it embedded in the thermostat itself? if so you should be able to replace the thermostat in full to resolve the issue.
No its in the thermostat housing itself and it only leaks from there when starting from cold?
sounds like you need to replace the housing then, its not too uncommon...
ah ok,was hoping to take plug out,clean and replace,hoping that would do the trick?
cheers,but was hoping somebody would have had the same problem and could fix without buying a new one.
Dont believe that you can replace the nipple on its own to be honest?
Cheers James,thanks for replies everybody.
As they are plastic the housings tend to go out of shape after 7 or 8 years and start to leak. Its worth changing the whole thing anyway.
Cheers Bruce.
