Xr3I Interior Water Leak
ive a water leak inside car and the water slightly runs down behind accelerator pedal. im guessing it could be coming in behind fuse box,any ideas ?
Check the bulkhead drain homes are clear from obstruction like twigs, leaves and dirt firstly. Has it got a sunroof? If it has, check the drains are clear. Can you see any visible corrosion around the windscreen rubber?
