battery light
i wonder if any1 can help?
ive got a 03 plate mk1 ford focus st170 and recently the engine management light came on with code P1246- Alternator load input failed possible causes wiring or alternator. the battery light is staying on when i am running the car? i have changed the alternator, the battery is newly new and im not sure where to look?
if any one can help me i need to get it sorted.
thanks
Possibly a bad earth from the alternator or could be a faulty alternator you've put on. Other than that, could be the fault codes not been cleared from the ECU and the car still thinks theres a problem.
thanks
hiya
thanks for getting back to me
the engine management light is not on now ive had it reset, the battery light is still on though and when the car is running all my lights are pulsing (Flickering)? but its still charging the battery?
hiya
If the lights on the alternator wont be charging the battery. So it will be a bad earth somewhere, the aux drive belts not tensioned properly or a faulty alternator still. If the aux drive belt is the same on the petrol as on the diesel the belt doesnt come into contact with the alternator pulley much at all. I'd prefer to see it going 180 degrees around the pulley but mines 90 at most, I presume the petrols the same so a properly tensioned belt is essential.
