Ford Fiesta 1.4 Durashift Conversion To Manual
Hi all I have spent the last few months trying to get a fiesta 1.4 durashift semi auto back on the road and I am stumbling at the last hurdle!! I first went down the route of relying on someone else to repair my clutch actuator only to be ripped off to the tune of £130 (STEER WELL CLEAR OF ECU SOLUTIONS WALES). After being ripped off I decided to have a go at converting the car to a manual. I have sorted all the mechanical side and the wiring the car now starts and drives hurray!! The only problem that I now have is that the speedo does not work. The problem that I am having is that my car has abs and the speed is calculated from the abs sensors rather than a vehicle speed sensor. What I am after finding out is the pcm/ecu part number from a 2003/2004 1.4 duratec engined car with abs as the donor car that I got the ecu from did not have abs.
MANY THANKS IN ADVANCE DANNY
  • 3 years later...
Hello Danny, what did you have to buy to carry out the conversion and what did you have to do to the wiring?
  • 1 month later...
Did you find a new wiring loom or did you modify the durashift loom that was already fitted please ?
