Transit Van Fog Lights
HI
I cannot get my transit van fog lights working there doesnt seem to be any power at the fuse...
no other problems with electrics just fog lights.
could it be a broken fuse box??
not sure what to do..
is there any way i could bridge some power to the fuse to get it working ( clutching straws )
i dont have a towbar fitted.
57 plate transit.
cheers
Hi Andrew,
it could be as simple as a bad switch?
thx for the reply james.
i did swap the switch for one from another van with working fog lights.
tomorrow i will check if power is getting to the switch. according to the circuit diagram the switch is before the fuse. i guess i will have to keep tracing it back till i find power.
andy
Check the fuse carefully, you might find its blown discretely
Sent from my MY SAGA C2 using Ford OC mobile app
tested the switch it works perfectly.
tested for power at the fuse connector with fuse removed no power at either end with ignition on foglights switch on etc.
heres the wierd part the wire that goes from the fuse box to the foglights has a small amount of current going through it......
i have in the last 2 weeks fitted new ply lining to the van wondering if ive gone through a cable. gonna test the screws for current now dont want to have to remove all the ply lining / racking.
:wacko::wacko:
i couldnt find the problem. ran a new wire from the switch to the foglights. it now works fine
Result, a nice quick fix then?
You must have screwed through the cable then.
Glad you're sorted.
