Debadging
Hello, I own a Fiesta Zetec MK7. I wanting to debadge the "fiesta" and possibly the "zetec". I have all the necessary equipment to do the job besides goo-gone. Is there any other house hold product that can do the job or is it best to go purchase goo-gone itself.
Any help is much appreciated
Giggs
to be honest you could probably use in small doses of course - nail varnish remover.
The Acetone is what removes the sticky and its safe to use on hands, but I would say if you do use that on your car, just use it in small doses, then wipe down vigerously with a generously wet cloth between applications.
Wd40 works well used it many times to remove sticky, but last time I used isopropyl alcohol as I had some.
Sent from my Nexus 5 using Ford OC mobile app
Giggs
some Tesco petrol and an old sock or something from the Ann Summers collection generally found in the rear seat of footwells after a long weekend,
Petrol will melt polystyrene which is what the badges are held to the body with.
when i debadged my mg zr i had glue left behind i found a combination of auto glym tar remover and hot water done the trick
