Ford Focus 1.6 Zetec Se
Hi guys i have a focus 1.6 petrol duretech and it has a fault i cant figure out when i accelerate it sum times feels like im getting pulled bk and then i can only touch the throttle bout a inch after an inch it loses all power but once left for 20min it will be sort of ok but still sort of misses when putting my foot down i have changed oil and filter air filter fuel filter coil pack lambda
I was told it might of been the fuel filter then i was told the cat was blocked and it causing back pressure but i unscrewd the pre cat lambda and still doing the same thing also tryed redx and no luck any of you guys got any ideas ps. Duretech has no maf sensor or egr and there is no engine m light or old codes
When was it last servied, the likes of the Fuel Filter replaced, EGR valve checked, Inlet manifold cleaned etc?
