Can Anyone Help
My escort van failed it's mot on the angel eye headlights they said the light pattern was wrong iv since changed them for original headlights but it's bugging me is there away of correcting the light pattern cheers john
Are you using standard bulbs? I used some different headlight bulbs in my lights a few years back and believe or not but even though they looked and performed perfectly, somehow they buggered the beam pattern up, so I used to have to swap them for the MOT.
Also are the lights e marked? If they aren't then maybe they aren't intended for use in this country, RHD vehicles, so the pattern will be wrong. You can put some tape over a certain section of the light, to block the area of light which blinds people coming the other way, then it should pass. Your tester, if he's half reasonable should let you do this if you ask him while it's aimed at the beam setter.
There's no other way that I no of to change your beam pattern.
Hope this helps
Old Fords do it sideways
Hi thanks for the reply they are easy marked and I'm using the bulbs that came with them I might swap out the bulbs iv also been told they have adjusters on them I won't give up
Thanks for the advice cheers john
