Remote Key Fob
Got a 55 plate C-Max with a remote fob problem!
I've replaced the battery and reprogrammed it as per the manual, and get the 2nd beep as if it's programmed correct, however the fob still won't operate the central locking.
Because it appears to reprogramme ok, I assume the fob is ok and is communicating with the receiver, but unsure as to why the fob won't operate the central locking.
Any suggestions would be most appreciated,
Thanks.
Probably fuse issue?
