Focus Mk4 Steering Pump
hi guys
having a problem with a steering pump I think as few days back was heavy rains and one day I got a problem with the steering pump and warning light saying assisted steering faulty
Started looking into it and I found the connectors are wet a bit at the pump
dried them out and next day all was good But there was a noise from steering pump and after few hours driving the steering went stiff again
checked the plugs again all dry and nice but the problem is there and no warning messages on dashboard this time
can it be a pump or something else
has anyone had this before
thanks in advance
Is the pump reservoir topped up with power steering fluid?
which engine do you have. diesels have electric power steering whereas petrol have the hydraulic system
Isn't it electro-hydraulic on all Mk2 Focus' James?
Ive got 1.8 petrol engine and its electric hydraulic one on it
i might be wrong but i think its the same on diesels and petrols as the part numbers the same on them
Hi, I had the same problem with a saxo vtr some years ago, that car had an electric power steering pump, when the steering went stiff we used to give it a bang with a long bar to get it working again, in the end we just replaced the pump.
Plugged to my mates autel maxeda or something like that today showed few codes the mains i guess were
steering pump malfunction
and steering angle sensor faulty
it looks like its the faulty angle sensor that makes the pump to malfunction
what do you guys reckon?
Thanks in advance
Does anyone knows where and how many steering angle sensors on 57 plate focus?
The steering angle sensor is fitted behind the steering wheel.
It's usually only used for the ESP though, I didn't know it was used for the EHPAS as well?
I thought its one angle sensor as well but when connected to diagnostic it showed two
on first it says steering angle sensor circuit open
on second one steering angle sensor faulty with the c1956 code
I found out that there are two one behind the wheel itself the second one on steering rack
Oh ok, in that case you know more on the subject than I do lol! So I cant help I'm afraid.
