New Injector?
Ok after 700 miles of injector cleaner i have just done another leak off test for 6 mins at idle,
1. 60ml
2. 45 ml
3 50 ml
4.50 ml
as you can see injector number 1 is 15 ml higher than the lowest reading (more than 30% higher). is this definately a sign that i need to replace injector 1.
If so which injector do i buy, its a 1.8 tdci 115ps year 2004.
I have seen various injectors such as EJBR02201Z and EJBR01601Z both supposedly for 1.8tdci, but what do these numbers and letters mean, which one do i buy?
Anyone
Help
Hi, I 've the same engine as you. I 'm interested to know how many miles you 've done and what injector cleaner did you use ? Why don' t you give your local Ford parts department a call :).
i have done 110k i used wynns injector cleaner from halfrauds.
84000 on my clock, maybe I should consider a clean out. Do you think it's made any difference or a waste of money?
I personally think you should use an addative to help keep injectors clean on a regular basis. Millers is about 13 quid should help reduce carbon build up. I used it from the day i bought thr car but injector was probably already goosed on mine, when i replace it i will keep using millers addative to hopefully keepit clean
