Warning Lights Galore
Hi guys after some advice. I have a 1.8tdci Ford Focus 06. Now iv had the management light on for a few weeks it reads 141a or something egr valve sensor. Now I no this is all one part and as the valve is fine I'm not in a rush to change it. However last night when going above 2.5 revs I get the red cog of doom. Reading the code relates to the mass airflow sensor.
I'm not going into limp mode and the engine is running fine. Will cleaning the maf cure this? Are the problems related. And can I ignore this while I save to fix the problem. Any help would be greatly appreciated.
disconnect the wiring from the MAF and spray with contact cleaner, allow to drive and off it should go, your MPG will suffer if you leave it unplugged.
As for the error codes, how did you read them?
