Engine Mount
Does anyone know how much the engine mount costs?
Its the the one under the coolant bottle..
The reason is ask is because when i pull away a bit had i hear a loud clonk noise and it sounds like its coming from that area.
I had one go on my old audi and its sounds very much the same noise..
Tho i am hoping its that..
Iv checked eurocar parts but they dont seam to stock that one. I thinks its the other one they have..
if you can help...
Cheers
You don't say what mk or engine size but all should be available cheap enough from any scrappy
Its a foci 2ltr 2005..
I never buy 2nd hand parts. Ill ring ford on monday.. Thanks
Check Ford Parts UK or Eurocarparts
Your car is right on the year change and you dont mention if its a Mk1.5 or a Mk2.
If its a Mk1.5 this is what you need http://www.fordpartsuk.com/shop/ford_focus_front_engine_support_insulator_f_1332880_c_359.htm
If its a Mk2 this is what you need http://www.fordpartsuk.com/shop/ford_focus_torque_restrictor_mount__f_1751001_c_589.htm
Hope this helps.
Thanks all
