Helllppp!!!
This morning I heard a whining noise from the car. Carried on with my journey but when I turned in the power steering went managed to pull up then the dash said transmission malfunction then the car died. I have no power at all! Won't even tick over.
Burning smell coming from behind engine. Any ideas?
Hi Warren, It could egr valve, mine went the same way as you say, or even the clutch a good garage one that you can trust, will tell you, it's not cheap! if its egr, and the clutch is not much better two types dual mass or standard.
Maybe it could be something to do with the blank I fitted and the fact it was only 2 degrees this morning.
When yours went did it tick over? My radio lights up but the dash is blank and nothing happens.
Car won't even lock lol.
Mine would not run, I just got to work and that was that, AA came egr had gone, £500.00 and two days later the car was fine, I don't believe in blanking off egr valve, the advantages compared with the problems it can cause are minimal, the locking could just be the cold, in the bad weather ice can stop the car locking its happened to me.
Just tried jumping it and the alternator started smoking.
I've got someone coming down to check it.
Well good news is a new battery bought it back to life and it's running now.
Got a noise coming from engine somewhere so going to get it up on stands and have a look for a leak.
The noise could be the alternator, as it shouldn't smoke, anyway the alternator is an easy fix, so get the tools out. lol :D
nearly forgot you will need to move air/con pump out of the way, its just 4, 13mm bolts, don't undo the air/con pipes
