Scraping Noise
Any ideas when turning the steering wheel to the right I get a scraping noise from the front wheel. and i have already had the steering rack replaced please help
thanks
Solved by antlock123
sounds like it maybe the lower suspension arm (wishbone). have a good look at it or have it checked and have the cv joint check as that maybe the cause
  • Solution
i have had new discs and pads track rod end and droplink and the noise has not gone the car handles alot better now as well but thanks for your help
when you had the steering rack replaced they should have done the track rod ends & checked the drop links. glad it's all sorted
