Clutch Slave Cylinder
Hi everyone
2012 Focus Zetec Sport 1.6 diesel 28k on clock. Started last week clutch peddle higher than brake and catching on metal bar that pedals attach to. Friday pedal was basically on floor. There was still about inch travel to disengage clutch / change gears but got Ford assist out as didn't fancy driving. Turns out a very rare fault according to garage but reading on line not that unusual. Turns out the clutch slave cylinder rod ( bit plastic) snapped and needs replacing. Being done under warrenty but i dont think something like that should go in less than 3 years and low mileage......comments, anyone else had this issue
The part on the pedal is the master cylinder, not the slave cylinder. Certainly not unheard of as you say though
